Hi,
I am working on a 60 Falcon with a 200 and a Carter YF, the arm on the carb is turned paralel to the fire wall. When you push on the gas the arm in the engine compartment pulls back.
Can I run a throttle cable from the existing arm (on the passanger side when standing at the front of the engine looking at it) around to the drivers side along the valve cover up over to the carb and attatch to the ball? This should make the cable pull the carb arm shouldn't it??
Help lost and confused in Central Florida
Chris
Chris
