I am needing some timing help for my 200 with a sniper 2300 and hyperspark ignition. I just finished rebuilding it. The engine specs are:
200 ci
Aluminum VI/CI head
10:1 compression(flat top pistons)
Schneider 135-H cam(270/270 Duration. .440 lift)
Factory non adjustable rocker arms
Sniper 2300
Hyperspark Distributor
C4 transmission
Do I start at 12deg or do I add in degrees that a vacuum distributor would add?
Does this combo need more initial timing?
What would the overall timing need to be?
Any help is appreciated.
			200 ci
Aluminum VI/CI head
Sniper 2300
C4 transmission
