I read on a few post some conflicting timing settings for the 200 I6. One post said to set the timing at 6 Degrees BTC and the other said that the specs were to be set at 12 dgrees BTC. I set it at 6 first and it ran good. I then readjusted it to 12 degrees and it ran even better. Is 12 degrees too much ? could the 12 degree setting damage any valves? also I read the idle spec to be at 475 to 500 RPM,s . I tried to adjust the idle down to 500 rpms and it just seemed to barely run. I adjusted it back up to 650 to 700 rpms. It would idle better. When I drive around and come to a stop . There is a slight shudder that is steady. Is it because the idle is a little too high? I have a pertronix set up coming soon. I hope that it helps.
