flash_point01
I'm new to the forum so please spare me and rest assured that i have spent much time searching past posts concerning this issue. I have a 67 mustang 200ci with pertronix ignitor I, MSD blasterII coil, pink wire intact, Autolite 46 plugs gapped at .045 a new set 7mm cables, and what i think is a holley 1946. The first issue that i have been having is that i cant find a distributor hold down to adjust the timing so instead i've been adjusting it by the bolt in the distributor, the second issue is that the timing was set at 10 degree's but when I went to advance it a little more it started hard, fighting the advance i assume, but runs like a champ. What concerns me is that my timing mark is about two inches past the 14 degree mark. Why would it run so great at this setting? Is there a danger to the engine doing this? I haven't driven since the change. Is it possible my timing chain is off and this would be an appropriate setting?
thank you very much
Chris
thank you very much
Chris
