72maverick
Hello,
I'm running a pertronix unit along with a superstock accel coil. The distributor is turned completely in towards the block (fully advanced, I believe). When using a timing light on it, the mark is way off the degree scale; however, whenever I try to bring the timing down the engine gets rough and stumbles. I bypassed the resistor wire so that shouldn't be an issue. Is the engine just going to be happy with the timing that far advanced? Or are there other things I can check?
Thanks for the help
Thanks for the help
