Egr valve failed recently, symptoms were major surging and lurching.
Plugged the vac line and capped the valve and everything is now smooth, but I understand with the 1946 it'll be running rich.
I am trying to decide what to do and have been thinking about running a vac line straight from the spark port to the dizzy, bypassing the PVS, and capping the other ports on the carb. And blocking the egr spacer, etc.
Would a smaller jet be appropriate? I don't know what size is stock but I think it said 299
: on it if I recall correctly. What would be the recommended replacement size?
The other option is to replace the valve.
Looking for suggestions on what to do here. :wrench:
