FWIW, the log mount tri power is a very poor kit, with poor porting giving inconsistant power due to different hole sizes between the center carb and the outers. For the early ones, 1.3 center, 1.09 outer, for the later ones, 1.6875" center, 1.4375" outers. Either way, the air fuel ratios are not even through the rev range, and you have to spend an amount of dyno time to get them working well.
If done right, you can get 143 rwhp with just three 29 mm progressive ICT Weber 1-bbls on a 200 cube 61 Falcon tudor, or over 210 hp with three ' straight unison linkage' Autolite 1101 in the center and 1904 Holley's outboard on a 65 Mustang (Drag car only) 250 Six + goodies , , 14.39 so far.
For 200 dyno figures, see kevinl1058 on
viewtopic.php?t=64712.
Flywheel Corrected # 177.05H.P., 204.20 lb-ft
H.P. peak at 5100 RPM. Torque Peak at 3250 RPM
Video
http://vimeo.com/20044528
For 250 quarter mile figures, see FalconSedanDelivery.
viewtopic.php?f=40&t=41798&p=502631#p502631
This guy is too quiet, his set up is very creditable 200-225 flywheel hp, and most likely the most powerful triple 1-bbl around. He runs a unison linkage, high initial advance of 16 to 18 degrees, total timing to 30 degrees its all in at 2350, decked block 100 thou and head 120 thou for huge 12.3:1 C/R, and the worlds neatest tri power intake ever seen. His 14.39 @ 91.76 mph was is shifted at 5000 and 4300 at the traps, earlier runs were 5200 and 4700 rpm. He ran with 3.5:1 gears for the 14.39. Best 60 foot time 1.915 secs in a 2600+ pound car with a an estimated 165 at the rear wheels.
