What carbs are you running? Seeing that it was running good for a few years, I'd lean torward a vacuum leak as well. Did you check around the base of the manifold - assuming you're running an Offy set up? Are you sure the outer throttle plates are still completely returning to closed - assuming you're idling off the center? Maybe try a carb swap (one of the outers to the center to see if that helps). Good luck, keep posting on what you're finding...
