most likely you can see the fitting that is going into the distributor and visually confirm that it is not damaged. It sounds like the threads aren't engaging completely as you try to tighten it up. There is a chance that you boogered up the starting thread inside the vacuum advance. If possible you should try to get the hard metal vacuum line as straight as possibe to aid in getting the fittings ligned up before starting to thread them together. Or if you have another fitting (brass perhaps from the parts store) with the same threads/pitch you can try to spin in something else in hopes that it either magically works, or straightens out the threads enough to work.
I hate working with hard lines, they have so little flexability that they can be difficult to get started.
lots of luck,
-ron
lots of luck,
-ron
