Axle Roads
Richard, if you look closely in the hole you can see a flat seat where, I think, the seal is made. I might be wrong, but I'm guessing as long as the adapter is screwed in all the way it will seal. Poor design, if you ask me. I added plumper's thread seal just to be on the safe side... no difference. I want to try a rubber washer next. I can't get too the rear end without taking apart the carb so I don't have a way to test the vacuum.
I like your idea of buying a cheap carb for diagnostic purposes. It would still have to be a load-o-matic right?
I have a manual choke.
