One of the main bearings will have flanges. The crank has two shoulders that locate the crank, for and aft. This keeps the crank from moving forward or backward.
When torque converters go bad, they can push forward on the crankshaft and cause a heavy load on the thrust bearing. This will wear out the bearing and the rear thrust surface on the crank.
When checking for excessive clearence on the thrust bearing, you need to move the crankshaft forward and backward and note how much the crankshaft will move. The belts on the front of the engine will prevent you from moving the crankshaft. Relax the belt tension and try to pry the crank both directions.
