Hello all,
I have a 63 falcon with a 170 in it. I would like to put a turbo on it, but I am not sure what to do with the ignition. It has a "load-a-matic" distributor with vacuum advance only.
Also, to make things more difficult, it seems that the distributor can not be upgraded because the hole in the block on these early engines is too small for the later distributors.
I could run some extra initial advance and the stock vacuum, but as soon as any boost comes on, all of my vacuum advance would go away.
Would the engine run under boost at higher RPM with only 15-18* of advance?
Does anyone out there have another viable alternative?
Thanks in advance for the input.
~Jim
~Jim
