Emerald 74 4X4
So I got my exhaust system installed and was able take the truck for a good drive to get it tuned up a little. Was able to get it to cruise ok with only a barely noticeable lean miss from time to time (almost seems like a timing problem more than a fuel problem). The initial acceleration is good, but then it tends to lean out when the MAP nears 15 to 0 inches Hg under load. Seems to want to run lean a lot and can hear pre-detonation under heavier loads.
Then my computer battery died and that was the end of tuning for the day.
I'm not sure how the ignition curve I have setup is doing well or not or if it is making it run leaner. I have not been able to make full on boost pressure yet as I'm trying to tune the under 100 kpa areas first. I do notice that the MAP reaches zero more quickly for only having 3/4 throttle though.
