Finally...the corty moves again!
I ended up getting a 2800rpm stall from TCT in springvale.
This time the guys at TCT were spot on and said that it shouldn't stall over about 3300 - 3500 when under hard boost.
The car feels excellent with firm gear changes.
I will take it to Calder soon.
While I was waiting for the converter, I put in and electric water pump and thermo. The only reson I did this is the ability to keep the pump and fan going between runs.
I guttered all the internals of the standard water pump and took off the whole front section to allow room for the thermo. Interesting is the fact that once you press out the waterpump baring, you can block the hole with a welsh plug - cant remember the size, but its a perfect tight fit.
cheers
