As the title implies, I've been piecing together a kit to sell that will include the following
Factory 2.0 or HD 2.5 outlet J pipe with either Vband or t3/4 flange
HX35
Intercooler for those running any form of fuel injection or added cooling for blow thru style tbi/carbs
Wide band O2 sensor
Turbo cobrahead 90 degree for turbo
If running draw thru will include the below
Throttle body for mounting to stock log intake
Carb with throttle plates removed to prevent a vacuum coming from the compressor housing
Then cables for the throttle body and carb throttle off of throttle body
The design I have tucks the turbo right next to the exhaust to allow for installation in a e series van, I've been able to do a Fit test with an 88 van and not have a space issue, so that the people with vans can have a choice too
This kit is put together to run around a max of 8 psi for a reliable build
I will offer a warranty for it for all of the parts including the turbo, if parts were damaged due to the owners actions I'll offer a discount for parts one time
After that, any further damage caused by the owner will result in needing to buy an entire kit
I plan to warranty the kits out for 5 years or 75k miles
This is my plan for everything
HX35
Wide band O2 sensor
