Hi all,
need to know whether the oil return from a turbo can be drained to a higher point on the motor than the turbo itself??
eg the drainage holes in the head....
so the oil pressure from the oil feed pushes the oil up into the head,, will all the oil stuck in the turbo affect its running?? and will it stuff up eg boil the oil in the turbo on shutdown?????
if the above will stuff something up.. how can a drainage into the sump be made without removing it... i don't think drilling or welding are good ideas... any ideas.?????
metal shards in oil and oil lighting on fire are not the best things for engines.
