ya so I got up this mornign and decided I Wanted to take my car out for a spin, and while out I HAD to doa burnout, well I stopped in an empty area and brake torqued and spun em' till it hit the limiter at 5k and let off the brakes and looked at the boost gauge and saw the boost was climbing from 10 psi and went up to about 15, and I let off, I made sure the vacuum lines were all hooked up properly and made a quick run in 1st and it spooled to 10 stayed for a second or 2 then started climbing to around 12 before I let off. This is the 1st time I had driven it hard since I got the manifold sealed and the exhaust off. anyone know what would be causing this? can the wastegate not keep up orrrr? Thanks, Tommy
