using teflon tape
kirkallen143
Howdy All,
when it comes to sealent on the oil line to the turbo, is teflon OK? I heard somewhere do not use silicone based. Thanks fellers.
Kirk ' 73 bronco
Use TFE tape ONLY on NPT or BSPT threads in a steel to steel joint (or steel to iron.) Never use tape on any other type of thread and never, ever use it with aluminum, zinc or stainless steel. When in doubt don't use it, rely on a TFE filled pipe dope.
All other thread forms used on fittings have some kind of auxilliary seal like an o-ring or a doty seal which is all you need or want although a TFE-filled dope can give an extre measure of security and helps lubricate during assembly. The 2 tapered thread forms need something to fill up the spaces to prevent leaks, therefore TFE dope and tape. The problem with tape on Aluminum stainless and zinc is that it can actually promote galling and make disassembly/reassembly impossible, not to mention ruining the parts, TFE-filled dope causes no such problems.
One more thing. Never use tape anywhere where small pieces of the stuff getting carried downstream can cause a big mess by clogging vital ports, etc. Basically, use tape when you re-plumb the crapper and not when you fix the car.
When you do use teflon tape, be sure you install it properly.
If you wind it wrong, it doesn't seal, and makes a mess.
This sounds like a joke, but if you are holding the fitting in your left hand, tell yourself "red right returning from sea" and wind the tape underhand using your right hand. An old master mechanic taught me this years ago, and it always worked for me.
Oh yeah, my buddy is a plumber. If you hold the piece in your left hand, turn the tape away from you. Appreciate the info, though.
Kirk ' 73 bronco
I always "thread" the tape on. they say not to use it on turbo supply lines because if some gets in the oil it will get in the turbo bearings this is bad. I like using a dope instead..looks cleaner and is faster.
I just happen to be at Home Depot and they have a yellow teflon tape especially for gasoline and other petroleum products using threaded lines. It is about $4.00 ea., and says only need two full wraps of the threads to be effecient.
Kirk ' 73 bronco
Kirk ' 73 bronco
That yellow teflon is specifically for natural gas lines. It doesn't say anything about gasoline on the box.
No, it says right on the spool's cap, itself...for use of gasoline, petroleum products, propane, natural gas, etc...
Not to say wrong here but that is what I read.
For the Keepers of odd knowledge (KOOKs):
Do not use teflon paste on PVC. The solvents used to keep the PTFE in suspension will degrade the PVC.
The pipefitters here use a combination of tape and dope on stainless.
My experience with SST and tape vs. dope is that if it goes together the first time and doesn't leak, tape is OK but if it leaks, you're screwed (literally in this case) because the tape will gall the threads during either initial assembly or dis-assembly and you end up re making pipe. Anything that has to come apart is most likely history. We instruct our fitters to use dope only on SST. On the rare occasion that they listen, we have no problems.
Been working at Vortec Superchargers this summer and the majority of units that get returned are for failed oil seals. As I was talking with one of the master assemblers, he mentioned to never use teflon tape on the pipe threads. His pet-peave is when returned units are opened up only to find teflon tape clogging the oil filters. All the new and rebuilt blowers are put together with pipe dope. For universal units that are sold with fittings loose, a large tag is put in place warning the installer to not use teflon tape. If you're curious. I can ask what paticular type/brand they are using.
I don't like the "chunky" teflon pipe dope fron the hardware/home supply.
Permatex brand has a very high quality teflon thread sealant liquid at the auto parts stores and is more specifically designed for the finer threaded stuff in automotive applications. It also seems to seal better.
