I was reading in the Factory Manual about adjusting valves and the 65-66 manual has a very detailed explanation on checking for valve clearance but it applies to Non-adjustable rockers.
Can someone point me in the direction of some information on setting adjustable rockers.... Do I need a later model book???
I am trying to learn as much as I can about all of this, but there are a lot of different procedures for different setups....
Also, the manual is using one of those famous Ford tools to bottom the valves and check for clearance, what do you all use instead of the "Ford Tool"
This is all starting to make sense to me now. I am going to tear off the rocker assembly this weekend, thougth I might play around with the old setup and figure things out as I tear it apart, nothing like looking inside to really see how things work together....
