Rustang Racer
I'm rebuilding a C3 head that is going onto a 250 with a Clifford 264H cam. The intake is going to be milled flat so I can direct mount a HolleyWeber5200 at first (because I already have it), and later a Holley 500. The exhaust is fully ported and polished, the bowls are blended and pocket ported, and I did all I could to port the intake (which isn't too much). I'm going to unshroud the valves as much as I can. What kind of valves do you guys recommend and could you give me the original application for the valve too? For the exhaust I've heard about using 144ci, 1.44" intake valves as exhaust valves. I've also heard of SI stainless 1.50" valves. For the intake I have the old 1.69" valves right now and could go with the later 1.76" valves or SI stainless 1.80" valves. I'm not sure what application those SI valves are listed under though. What do you guys think I should use? Are there more good valves other than the ones I listed?
