Titleist16
Today I was working on an exhaust leak and then changed my oil. After I changed the oil I started my car up and I heard a ticking. I took the breather off and looked inside the valve cover and I didn't see any oil flow or movement. Should you see oil moving in there? What could this ticking be? I switched from Mobil 10w-30 synthetic back to Castrol 10w-30 regular oil and used a K&N filter. My pressure gauge is showing 40psi.
