Hello All,
I'm in the process of sorting out a '95 4.9 EFI from an F150 for final installation in my Jeep. It appears that the VSS is part of the anti-lock brake/programmable speedometer. I don't plan to use those parts in my swap, nor can I use a sender that inserts into the transmission. I'm using a T19/Dana 20, so I will need a sender that goes inline with the speedo cable and threads ONTO the transfer case. What are folks that have swapped in the EFI system using for a VSS.
Thanks..
Thanks..
