One thing we learned welding all the conversion blocks was that cast welds better if preheated.
If you first prep the crack for welding, then build a nice charcoal fire and heat the manifold very hot, you can get a nice weld with an arc welder and a nickel rod.  After you've welded it, just let it cool by letting the fire burn out with the manifold in it.
