Alright, so I cheaped out and bought a 27$ spectre AFPR from pep boys. I installed in and it seemed to help a LOT.
After screwing around for a little, I've got it set at the max (5.5) and the carb no longer overflows. I think I might be draining the bowl on acceleration 'cause by the time I get to 3rd and 4th gear it starts to fall on it's face.
I don't have any pressure reference right now. What I am thinking is that If I start out w/ a full bowl - I have enough fuel there to make it through like 3rd gear. Then It starts to go dry. Since I don't have a pressure reference, anytime I am making more than a few PSI of boost, The bowl is not filling because it is at higher pressure than the incoming fuel. It takes a finite amount of time to drain the bowl, which is why I only see the stumble after a few seconds on boost.
If I let out and get out of boost, and then go for it again - It pulls again. That would make sense if the bowl filled back up.
So, Either i've got to figure out how to boost reference this cheap AFPR I bought, or just deal with it. It's not a huge deal right now anyways 'cause it only happens if I go full throttle through the gears. Just normal driving it doesn't seem to be a problem.
Only remaining issue is that my wastegate doesnt seem to be opening. I will easily build as much as 10 psi w/ a 6 psi wastegate spring.
But, I can test that on the bench.
It pulls REALLY hard in 2nd gear haha
