Well, I drove it...
Bort62":1l98s9yw said:
I do run PCV off the back of the VC, but under boost that is sealed off.
Did you check the PCV valve to make sure it is indeed working as a check valve? A little tiny bit is normal, but too much leakage will cause massive blowby.
Yeah, I did check it when I installed it. If it is leaking, that would be new...
