What air clearner should I use on a HW5200?
Vin Man
What air cleaner fits on the Holley Weber 5200 2bbl carb? It has a weird shaped top (not round) so I don't believe a standard round air cleaner will work.
You can use a standard off the shelf 4bbl air cleaner and then make an adapter that fits the top of the carb and has the same outer diameter of the 4bbl air cleaner, or there are manufacturers that make air cleaners specifically for the 5200.
-ron
Thanks - I found the sticky on the weber carbs and went ahead and purchased teh Chirco air filter for about $22 after tax, shipping and handling.
