what do i need to put a 2100 on a 200
stang65
Active member
hi
what parts do i need
i have a 2100 and a transdapt adapter
pics are welcome ;-)
thanks marcus
Whats the setup on your car right now and we can go from there. Tranny, type of accelerator linkage, things along those lines so we can guide you in the right direction.
hi
stock 200
autolite 1100
with header
c4
original acc.-pedal and linkage modified to fit the header
thanks marcus
You will need the adapt the 1bbl to a 2bbl carb. I believe ClassicInlines sells those adapter.
Then, I would recommend you go with a throttle cable setup. Get an accelerator pedal and linkage from a 64-68 V8 Mustang. Then, get the Lokar throttle cable kit. CobraSix has a good write up on how to do the throttle cable conversion.
