What Exhaust System ..
Okay I have about 200.00 left. I need an exhuast system (pipes and all.. i got the headers already). I can't seem to find n e exhuast system for the ford 200ci. I dont know if this helps, but this is the header -- > http://www.cliffordperformance.com/Site04/Home.htm . The FSPP header was sold out, so i got those headers. Okay, Imma need dual exhuast 2" ..
Okay, remember that guy that is rebuilding the engine? okay, today my grandpa todl me that he was gonna put in new cam shaft with that 850.00 (which is actually 880.00)
check with local shops, the shop I use charges me $120 out the door (cash, no questions, no receipt, no emissions) on two V8 swaps I did for true duals from the headers back, h-pipe turned down before the rear axle. All aluminized 2 1/4 pipe. Not bad IMO.
Call around to you local muffler shops you should be able to get something for arond $200
Did you confirm that Clifford will be able to ship your header. I would also spring the extra bucks for the coated header. It will last longer
