Eric Rose
In my older hydraulic cam engines, sometimes I'll substitute a quart of ATF for a quart of oil. Its good as a detergent and the hydraulic additives are good for the lifters. I've seen lot of engines with ticking hydro lifters quiet down after adding ATF to the oil. A transmission gets just as hot as an engine, so you don't have to worry about it burning off or degrading from the heat. If you've got a recent rebuild or a low mileage engine its not needed, but its worked for me on well worn engines.
Also, I stay away from Fram oil filters because they use generic anti-drainback valves. Its probably not a big deal of these old Ford engines, but the Fram filter spec'd for the water-cooled VW engines doesn't have the right valve in it and it causes lower oil pressure than the OEM filters. I stick with Puralator Gold, WIX, or Motorcraft.
For transmission fluid, I am partial to type F because I like the firmer shifts. But if your transmission leaks or burns fluid you might want Dexron because its easier to find at gas stations and such. Some of them don't carry Type F anymore. You can mix type F and Dexron without any trouble so you don't have to worry about that. Most of the "aftermarket" brands of transmission fluid like Hurst and B&M are really just Type F.
