From the Chevron website about DEXRON
Chevron Automatic Transmission Fluid DEXRON®-VI is formulated with high purity synthetic base stocks. It is designed to maintain its viscosity through excellent oxidation stability and use of long lasting viscosity modifiers. Internal General Motors tests have shown more than twice the durability and stability in friction tests compared to standard DEXRON-III fluids. This will ensure consistent and smooth shift performance, even under extreme driving conditions. Extensive validation testing by General Motors has shown DEXRON-VI to be significantly better than previous DEXRON fluids in nearly every performance area.
Chevron Automatic Transmission Fluid DEXRON®-VI:
Maintains friction control for smooth, consistent shifting
Prevents clutch shudder in torque converters
Improves fuel economy relative to previous DEXRON fluids because of lower viscous drag and outstanding low temperature pumpability
Practically eliminates transmission overhauls due to sludge, corrosion, and wear
Operates well over a wide temperature range
Resists thermal and oxidative breakdown
Provides sufficient viscosity at high temperatures with minimal sheardown
Protects gears, bearings, clutch plates, seals, bushings and other components from wear and degradation
Resists foaming and thereby gives better operability and longer equipment life
Customer Benefits
Chevron Automatic Transmission Fluid DEXRON®-VI delivers value through:
Warranty coverage as an officially approved General Motors fluid
Improved durability of viscosity and frictional properties to ensure smooth operation in General Motors transmissions
Extended drain intervals of at least 100,000 miles under normal operating conditions
Back serviceability to cover all earlier DEXRON recommendations
Applications
Chevron Automatic Transmission Fluid DEXRON®-VI is designed specifically for use in all General Motors HydraMatic transmissions produced for Model Year 2006 and beyond. It is the latest generation technology approved for use by General Motors in automatic transmissions and automatic transaxles where a DEXRON®-VI fluid is specified. It is also back serviceable in transmissions calling for DEXRON®-III or DEXRON®-II fluids.
Chevron Automatic Transmission Fluid DEXRON®-VI is not recommended for use in transmissions which do not specify a DEXRON® fluid. In particular, it should not be used in applications which call for Allison C-4, ATF+3®, ATF+4®, or MERCON® type fluids.
Chevron Automatic Transmission Fluid DEXRON®-VI meets General Motors specification GMN10060 and has been registered with license number J60308.
Do not use in high pressure systems in the vicinity of flames, sparks and hot surfaces. Use only in well ventilated areas. Keep container closed.
Heres some good reading about fluid types and thier applications.
http://www.chevron.com/products/ourfuel ... nsmission/
