Reading through some recent posts it seems the 250 must produce much more power than the 221
although its only 500cc bigger. I have a good 221 with great compression 170 - 180 psi on all pots, 308 inlet valves, stage 1 mild cam, pacemaker extractors, 2.5 inch exhaust system, XE electronic ignition, Weber 34ADM carby onto a enlarged inlet. Diff is 2.92 and tyres are 215/65/14 and single rail 4 speed. The motor sounds good, goes and runs great but there is no way in any gear (unless it's wet or I am going around a sharp corner) that by simply slamming my foot on the throttle that it will break out into a spin.. I also had a good XF with simliar setup and it was the same.. I would like this wheel spinning power and I have a 250 motor that is running but would probably be best with a rebuild. Or should I just get an 8.. :x or change my diff ratio ?
Cheers Dan
Cheers Dan
