Well I had the fairlane out a few times a few weeks ago. it was running smoothly, Idling smooth accelerating consistently. Was still having a heat issue. It's getting pretty darn warm, then starting to run like crap, at idle, at speed, just everywhere. Also dying when it got to the extremes of the gauge, but it never pegged. I'm currently trying to figure this out. running the stock radiator, that looks clean and clear, four blade fan, new water pump. I'm looking to find a good quality aluminum or upgrade radiator to replace the stock with and possibly a five-seven blade fan to get more airflow around the radiator and engine. I'm hoping someone can point me in a direction with this issue, probably bubba, as he has a 63 fairlane??
Now the worse. I took the car out last week, it drove amazing, I put in some decent springs on the distributor and got a bit early advance which helped a lot, adjusted the timing to 16*@850-idle. then got the 24* advance in around 2900 rpm. running ported vacuum. I got a bit confident in her and she wasn't getting near as hot as the day before, so I was confident to get on the highway for about five miles. I got up to about 65mph(per gps) and realized its running at a hare under 4k rpm. I gave it a bit of gas to see how it'd handle 72ish for me and when I got up there the engine just stopped... oil light, gen light, solid coasting down to zero.
I pulled to the side, waited a while and tried to start it again, but no luck there. Got a tow to my parent's place and with the 98* weather said eff it for a few days so I can go at it calmer and more relaxed.
I got a chance to work on it today, figured it was the D.U.I. crapping out on me. Everything tested out fine there though. kept the dizzy off and bumped the throttle, no rotation. I pulled the dizzy out and it had twist to it, like aligning to the plug and the gears looked great!! Figure I sheared the cam pin or something now. We started looking around a bit and notice a huge splinter in the timing cover right in front of the cam gear. We cursed and pushed it into the garage. Unfortunately It's still 95* and 95%humidity here so We are taking things slow and getting our ducks in order to try and get as much worked out as possible in one shot.
So in a wrap, I need to tear down the front of my engine and probably the head to inspect for valve and piston damage, to be safe. I also need to find the best way to correct the rpm issue. I want to look for wheels and tires for some of it, but also am looking into a lower than 3.55 rear end and maybe putting together a very VERY inexpensive t-5 swap... But if I do the rear gear I am going to look for LSD on the cheap as well. AND lastly, I'm looking for solutions to my heat issues. I imagine my radiator is a bit over-worked for my build, so I'm looking and it almost looks like a big block or hi-po 302 radiator will fit pretty close, but I'm not sure. If I do a radiator swap, I want to do it right, If possible a decent aluminium cross flow. from the looks of it it's about $150 difference and likely worth the difference to handle these 100* temps as of late. Then the other possibility is the fan, It LOOKS like a few fans will swap on directly, but will it actually help enough, maybe promote airflow to get the hot air off the headers from getting to the intake and carb?
Gerald
Gerald
