Where can I find paper air cleaner for Autolite 1101?
cdherman
I have a 240 (yes, I know they have their own forum, but they don't have this carb very often and you do!) that has an Autolite 1101 on it (maybe a 1100, but I doubt it).
Anyhow, it has an oil air cleaner. The carb neck is just a 2 1/16 OD pipe, with a threaded rod up the middle. I assume this is standard for a 1101, regardless of year, and car/pickup it landed in.
The oil breather sits in the neck. It works OK, but I'd really rather have a paper air cleaner.
Anyone know of a source? Got an old one laying around that I can buy?
I know, I could custom mill an adaptor (I have looked all over for an adaptor to 5 1/8" with no sucsess), but I keep on thinking there MUST be someone who went to a differnt carb and tossed the old one and its paper air cleaner in a corner!
Thanks!!!!
If I'm correct, the Autolite 1100 and 1101 is the same carb. I used to buy Fram air filters.
Purolator: A30045
Fram: CA184
Andrew
Yep, I know they are essentially the same carb. I need the air cleaner that those filters you used to buy fit in!!! What year/model car had it, if I may ask?
Thanks.......
So you mean the sheetmetal housing for the filter, top and bottom? You currently have an oil bath air cleaner?
i have the original 68 mustang 200 air cleaner I am not using...
I am using one of of a 66 cause I think it looks cooler...I'll sell you mine...needs to be painted and such...if you are interested, I will snap a pix of it. I am not intereste din making tons of money...infact, i am just clearing out stuf.,...
let me know
chaz
ps...it came off of an autolite 1100...
Chaz
That sounds good. I tried to email you, and the system did not bounce the message back, but I havn't heard back from you.
Can you email me? My email in the system is correct.
cdherman // David Hermanns
