Where did you run your fuel lines?
tjnavyblue
Hey Will (or anyone boosted),
Any advice on where to run the fuel lines (feed and return) from the pressure regulator back? I'm looking at mounting the regulator on the firewall, but from there back... what solutions have you guys gone with? Straight down the drivers side of the tunnel? I've heard of people being nervous to run fuel lines in the tunnel lest the flywheel explode, but is that really an issue on an engine that will redline at 5k?
Thanks!
Factory EFI setup runs from the passengers side of the engine, over the trans and straight to the frame rail on the drivers side- then follows the drivers side frame rail back to the tank.
