kirkallen143
rbohm":ny1et1oc said:8)
for those of you that are building turboed engines by the way, use the dual diaphram unit, and plug the vacuum line in after the turbo outlet. that way you get a boost retard function automatically. it really works nice to eliminate detonation under boost.
THIS IS ONLY FOR A DRAW-THRU TYPE TURBO SYSTEM. Do not use this for a blow-thru turbo system. When under boost, the vacuum changes to boost and will actually advance timing through the retard port, pushing instead of pulling. Ask me and a headgasket how we know.
Kirk
