I'd not use the 10.5 if you were running a larger jet. I'd go down to 6.5, 5.0 or 4.5 power valve, which comes in only under wide oen throttle. You'll never gonna stave it of fuel with a Holley 2-bbl with V8-style jetting.
I think
Linc200 was runing just
one :!: 72 Holley jet when he made a low 13 second pass in his Turbo 200. He had one 1946 1-bbl carb and 16 pounds of boost, you guys have like two and half the boost.
Most stock 200's with a 500cfm carbs like a 65 to 68 jet, and a good restriction to the two power valve channel restriction holes each side of the power valve. Using WsaIII and Linc 200's fuse wire trick, it may be a good idea to insert some15 or even 20 amp fuse wire in there to ensure the engine doesn't die of too much fuel. Bearing in mind a stock instillation in a 390 cube 500 cfm carb had 73 jets, a 10.5 power valve may mean the engine is running like 10:1 air/fuel ratio, or equal to running a huge 81 jet .
Even if you guys were getting , say, a 130 hp flywheel hp with some really good mods, the turbo at 7 to 9 pounds wouldn't need to be jetted as rich as a 390 Ford. The boost ratio is only about 1.6 times a standard 200, which works out to being like a 327 at full boost. 130 hp with a 9 pound boost is like 210 hp at the most. Stock 73 jets can yield 350 hp on a really good 289.
As long as you advance the ignition to about 14 degrees static, and then restrict the total advance to 28 degrees at 3500 rpm, then you won't need to fuel it up that much.
The 200 just doesn't need that much jetting when you've aslo got two 60 size holes putting gasoline into the intake as well.
I'd look at
Does 10s jetting and power valves, he runs a tiny little 350 cfm carb, and IIRC its not even using a 73 jet with over 300 hp at the wheels. A 500 can run as big as an 82 jet on a big block 2-bbl.
I may be a little 'anti turbo' at times (possibly its envy. I've never had more than 9 pounds of boost to play with in a tiny 2.3),
It doesn't matter how you get your boost, the carb doesn't need to leak fuel like an English oil refinery to make a good blast
Enjoy yourselves. Wheres wsa111i and his Innovate LM-1 air fuel ratio tester?. Perhaps we need to set up a rental fuel ratio tester at mates rates, and do our own R&D!
