Which PCV valve
Williboy
Supporter 2018
Which PCV valve is the right or best one??? There is so many different ones. What's the difference besides size??? Should I go with the the one for my year motor or since it's slightly modified is there a better one??
I remember someone talking about the car running bad untill they replaced the PCV with the correct one.
I would like to get one that is 90* to make the hose run smoother.
Also is it better to run the line to the manifold under the carb or to the aircleaner???
