If you use the 200 pistons w/170 crank the deck height would be so low that the compression ratio would be down arond 6:1 or so. It would indeed run, the idle would be nice and smooth. Don't expect much performance when you step on the go pedal though. That compression would be about like the flathead sixes of the 1940's, or your Briggs & Stratton lawn mower engine. I certainly wouldn't recommend this combination, but it would work nicely with a turbo and about 20 psi boost 8)
Joe
