will radiator fit
do any of you guys know if a 3 row radiator, the ones you see on e-bay will fit in a 1963 falcon. if you read the application of these radiators they are all for the v-8 cars mine is going to have 200 6cyl. thanx cocacolaman
Might want to search the forum for "radiator" or "overheating" as I remember there was a lot of discussion a while back.
A V8 radiator won't work. You can find I6 radiators on eBay also. I got my new radiator from Advance Auto Parts just as cheap. It was listed for a 64 Falcon, but fit my 61 after bending the lower bracing to the radiator support. The new radiator was a little longer below the mounting nuts than my stock 60 or 61 radiator. The radiator is also thicker. My fan is now very close to the radiator. I am using the 6 blade metal fan that was used with A/C equipt cars. Everytime I start the engine, I hear a noise that sounds like a fan blade hit something, but I have not developed a leak. I need to get an even thinner profile fan, or modify the radiator support to move the radiator forward slightly before I do wreck the radiator. It does run alot cooler than before.
saltwaterfalcon1960":1mngbs9o said:
Vee-Eight has both outlets on riders side.On 6cyl the top outlet top is riders side bottom is passenger side.
All of the V 8 radiators I have have the bottom fitting on the driver's side and the top on the pass side.
thanxs guys ill do a little more research thanx again cocacolaman
