wiring/vacuum diagram help needed 65 mustang
Got the car running. :D Now if only I had a wiring diagram/vacuum diagram. I can't seem to find a vacuum diagram. Any ideas?
It is a 200CID engine with the C4 transmission. Also still need an inspection plate for it.
Ellen
What vacuum does it have? Is it an aircon car? Simon has some clues on this, and Coupe Boy good archived references.
Regards, Adam.
according to the shop manual, for a stock `65 engine, there are three vacuum lines at the most:
1. carburetor spark control valve to vacuum-advance canister of loadomatic-distributor. If mismatched, make sure you have a dizzy which sports centrifugal advance as well, hook up the vacuum to the intake manifold, and plug the timed venturi vacuum fitting on the autolite 1100carb.
2. manifold vacuum to vacuum diaphragm unit on automatic transmission
3. manifold vacuum to vacuum check valve at brake booster.
manifold vacuum usually is picked up from vacuum fitting on intake manifold, just underneath the carburetor.
what specific wiring are you looking for?
