XE Instrument Cluster
The instrument cluster I have in my xe is the standard one with the fuel and temp gauge and the speedometer and econogauge can I straight swap it for one out of an xd with fuel, temp, oil, volts gauges, tachometer and speedometer or is the wiring different ??
Thanks Joip
It will plug straight in, just have to change the oil pressure sender and block the vacuum line to for the econo gauge.
Got another sender from the wreckers just have to hook it up and see how it goes
Thanks fingers
Joip
