bookworm007
I have read up on the other posts about this and know that normally you either use the 255 pistons, deck the block, or use jeep pistons and bore the block way out.
First let me fill in some background on my planned engine build. I'm building a 1970 250 that will have an aftermarket cam, DUI ignition, header, crossflow head ect. I already have the head and I am aware of the work needed to make this conversion and that it is not the cheapest easiest choice. My biggest problem is that my crossflow head has small combustion chambers like 42cc small and even if I opened it up to 52cc zero decking by the conventional means would result in way too high of compression.
I did some number crunching and found 3.72 dia piston (it comes in more dia to suit a .02, .04, and .06 over bore) with a 1.310 compression height. According to my math if you used one of these pistons on a 300 rod it would zero deck the block with no machining. The piston also has a pin size of .905 so it could be honed out and used with early 300 rods and pins or bushed and used with the newer rods.
Now the reason I am interested in them. On top of improving the rod ratio of the 250 these pistons have an ample 12.37 dish allowing more economical compression ratio. With my head it just allows me to stay on pump gas without boring out my block but with larger head you could keep the compression ratio down in the 9's with the right head gasket.
Here is the series of pistons i am looking at:
http://www.summitracing.com/search/Depa ... Rank%7cAsc
And here are the 3.72 dia ones I am specifically looking at for my build:
http://www.summitracing.com/parts/UEM-1743H-5MM/
I could only get a 10.7:1 with a 52cc head, .050 compressed head gasket and assuming the pistons sticks out .010 after you do minor machining to true the mating surfaces. If you had a 62cc head and made the same assumptions you could have a 9.5:1 compression ratio.
I posted this info on an aussie thread I was using to get specifics on using the crossflow head but I wanted a few more opinions who have messed around with trying to zero deck these blocks.
