I am in the middle of a major engine update.
One thing I came across was a worn distributor gear on a remanufactured duraspark distributor.
Any owner might want to check their gear before the camshaft gear is worn like mine. This forces me to replace the camshaft a clay smith 264.
Just a warning to prevent you with the same bad news.
This may be a good time to replace your duraspark with a DUI from Mike @ FSPP.
If not you had better replace your distributor gear real soon or at least inspect it. Advance auto carries the sorensen brand, you need the DG-14.
Before your camshaft gear is destroyed like mine at least check your distributor gear.
By the way you need a press to replace the gear on your duraspark & you better know what you are doing, this is no job for someone without a press & the necessary tools to make the swap.
In the automotive field, this could be considered a recall or at least a TSB-technical service bulletin.
Be on the safe side & check your gear. William
