KustomSkylark
It may just be me but is there anyone here that keeps their inline cool in Arizona without using an electric fan? I had a lot of problems with the last 200 I put in my Comet and after loads of tests I figured out that the water jackets were clogged up. I ended up scoreing a good deal on another block so I had the new block hot tanked(twice) and I rebuilt it. Now this block does 1000 times better, but it is still running hot.
Here is all the details, it's a '66 200 with a '79 head, bored .40 over, holley 5200 carb, 4 day old 3 row radiator, timmed in at 12 above(or is that below) TDC, drilled hole in a 190 degree thermostat, good hoses with spring intact, and 25% antifreeze 75% water with water wetter added.
The engine has about 600 miles on it. It's normal cool operating temp when it's in the morning or at night is around 200 degrees. During the day time in the heat it runs 210-220. It will get up to 230 idleing at a light. I won't let it go past 230, I usually pull over and give it a while to cool down when it gets that high.
Now I know Tempe Arizona has extreme heat, but is there anything else I can do aside from an electric fan or aluminum radiator? Are my temps normal? It seems point less to even have a thermostat if it never runs below the 190. What kind of temps are you other AZ guys runnin? I'm trying to make this car my daily so I can get rid of my newer car but I need to have full reliability in it. Thanks in advance for all your help and thanks for all your help in the past.
