Basically I've come to a few conclusions about old cars and cooling systems:
If anyone tells you that you just have to accept that an old car is going to overheat short of massive new radiators, electric fans, and all sorts of other do-dads is missing one simple fact.: The earth hasn't heated up enough yet to make a system that worked well in 1965 all of a sudden not work well in 2006. If you have a good, solid, clean system with working components, your car will run cool in any temperature. Clean radiators, cooling ports, working pumps, and Tstats will keep the car cool. You don't need 6 blade flex fans, water wetter, and 160* T-stats to keep your car running cool on hot days. The thing I've learned is all those 'remedies' only help mask the underlying problem. They are many times cheaper 'fixes' then addressing the real problem. Eventually the real problem will continue to grow and you'll be forces to deal with more overheating. I even think that my 3-row radiator is overkill since my car can not even hit 160* with a 180* T-stat during the winter and only hits 176* in the summer, idling for 30 minutes in 100*.
Slade
