mustangsilly
I installed set of CI dual long tube headers on my 66 convertilbe. Problem is the outlets are right in front of a body support and I can't get a pipe to fit straight on the outlet. I don't want to pry down on the pipes for clearance because I'm afraid it might stress the flange and/or pipe welds, maybe causing a break and/or leak. Mike at CI said to cut the down tubes back, but that would require pulling the headers and fabricating more pipe. Anybody have any other solutions? Any help would be much appreciated.
