2bbl head
Ba Mustang
2bbl head
Post #1 by Ba Mustang » Fri Dec 18, 2009 12:20 am
Is there a 200 or 250 head that will allow for a 2bbl carb to bolt up to it stock without any modifications? I've been thinking about getting one if they are out there to help me mod the 200 some more after I get rims and paint.
67 Coupe I6 to V8 - SOLD
2001 GT - DD
rocklord
Re: 2bbl head
Post #2 by rocklord » Fri Dec 18, 2009 8:44 am
There are no stock heads that will allow a 2Bbl carb to be mounted directly on it.
You could purchase a late head with the larger carb opening along with one of Mike's new adapters. This would be the best way to get a 2Bbl carb without
modifying the head.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
Ba Mustang
Re: 2bbl head
Post #3 by Ba Mustang » Fri Dec 18, 2009 9:39 am
I might just get a different head and use one of the direct mount adapters on it.
2001 GT - DD
170-3tree
Re: 2bbl head
Post #4 by 170-3tree » Fri Dec 18, 2009 10:15 am
Mike has one listed on his site, but no idea when it will be available
63 Fairlane Sedan, 200 bored .030 over. Aluminium head. Autolite 2100 1.08. DUI ignition. 274/274-112* Hyd. 9.5:1 compression. ARP bottom end. 2.77 3 on the tree(until she blows I guess) 8 inch 3.55 rear 5 lug all standard on fairlane.
2010 Mazda 3s 2.5l L4 6spd manual
1957 Chevy Belair 4dr post, 283/powerglide
Ba Mustang
Re: 2bbl head
Post #5 by Ba Mustang » Fri Dec 18, 2009 6:55 pm
I wouldn't buy a new one. I would rather spend that much money on a EFI 5.0 swap.
2001 GT - DD
Bayrunner
Re: 2bbl head
Post #6 by Bayrunner » Fri Dec 18, 2009 7:38 pm
How much HP can you get out of a 5.0? Real HP that you can afford? How much more weight will the car bare having a 5.0? Now, have you ever considered a 300+ HP Six cylinder?
Former Cars
69 Mustang Mach 1. Yellow
04 Mustang Mach 1. Screaming Yellow
03 Maserati Spyder Grand Sport F1
Current Cars
66 Mustang Coupe. 250 X Flow Conversion. 570 HP at Crank. Looking to break 700 with a larger Turbo.
08 H3 X -
3each Range Rovers for daily driving.
Ba Mustang
Re: 2bbl head
Post #7 by Ba Mustang » Fri Dec 18, 2009 8:03 pm
Bayrunner wrote:How much HP can you get out of a 5.0? Real HP that you can afford? How much more weight will the car bare having a 5.0? Now, have you ever considered a 300+ HP Six cylinder?
HP depends, I could afford it, weight doesn't matter to me. I have considered a 300, but I don't want to spend the extra money on a 3rd hood and I definitely don't want to mess with the two I have now.
2001 GT - DD
170-3tree
Re: 2bbl head
Post #8 by 170-3tree » Sat Dec 19, 2009 8:24 am
What if mikes came at a reasonable price? You wouldn't need to have head work done at all and it comes modified. It might be the best option for the money I just have no clue what it will cost.
Ba Mustang
Re: 2bbl head
Post #9 by Ba Mustang » Sat Dec 19, 2009 5:15 pm
It would depend on how reasonable. It would definitely have to be under 1k for me to even consider it.
2001 GT - DD
early ford fan
Re: 2bbl head
Post #10 by early ford fan » Sat Dec 19, 2009 5:37 pm
actully the falcon handbook says the 200 weighs 385 pounds and the 302 weighs 460 pounds.throw some used aluminum heads and intake on the 302 for maybe five hundred dollars and ill but the weight will be pretty close.
rommaster2
Re: 2bbl head
Post #11 by rommaster2 » Sun Dec 20, 2009 2:45 pm
Yeah the money to reliable power ratio with the 5.0 is just not a fair comparison due to the cheapness and displacement (for which theres no replacement) that said the sixes are just cool :). Honestly the mod doesn't look too hard and i'm seriously contemplating attempting it with my buddy in his garage and maybe even making our own carb plates.
That said i would love to pick up a late model head so i don't have to pay for bigger valves but it looks like every late model head for sale is way far away so with shipping i'd be paying the same as if i just got my spare 66 head worked over with larger valves.
170-3tree
Re: 2bbl head
Post #12 by 170-3tree » Sun Dec 20, 2009 5:05 pm
Obviously Mike doesn't have the modified heads listed, but he does list a lot of machine work at various prices things like two barel upgrade and porting options. It's not easy to find a late head for sale in some locations at all. which is my problem.
CobraSix
Re: 2bbl head
Post #13 by CobraSix » Tue Dec 22, 2009 8:59 am
dollar for dollar, the 302 will beat out a 200 and 250 for the price per HP.
Pound for Pound, the 302 will beat out the 200 and 250 for weight per HP.
Sure, there are other things that have to be done to convert, but still...the overall advantage will go to a 302 everytime. the 200 does not save enough weight to compensate.
Anyone who says otherwise is smoking something. There is a reason why the 289/302 block lasted for over 40 years in Ford's line up. Explorers had them until 2001. The amount of aftermarket parts for the 302 makes the price so cheap it's ridiculous. for the sixes, we used to have Clifford. Now we have Mike (who does keep his prices reasonable for the market) and our own innovation.
Building a six is not the same mindset as building a 302. If you want lots of HP. 302. If you wants lots of well documented builds? 302. If you want cheap HP? If you want to look like every other resto-mod mustang at a show? 302.
If you want to be slightly different? Build a 6.
I met a friend once at a show and shine. He brought his beautiful 68GT500. Gorgeous car. He parked beside my 65. Now, the pictures of my engine bay make it look better than it looks in person. It is rough. The car is now where near showroom or show condition. I had a bigger crowd around my car than he did. Why? Everyone has seen built V-8s. So little out there that hasn't been done already at least a few hundred times. How many people have seen a tri-carb 200? (which is what I was running at the time).
Slade
My Website
My How to's
Engine: 200 CI, Oz 250 modified for 4V Holley 390CFM, DS II Ignition, 40kV Flamethrower, MSD Digital 6+
Drivetrain: Cable Clutch, V-8 T5, 8" 5 Lug Rear End, 5-Lug SSBC Front Brakes, 3.40:1 Posi
rbohm
Assistant Admin
Re: 2bbl head
Post #14 by rbohm » Tue Dec 22, 2009 10:11 am
8) slade hit the nail on the head, so to speak. getting new aluminum heads for a small block ford or chevy for around $1200 is fairly easy because so many are sold. getting the classicinlines head for $1500 or so is still not a bad deal considering the limited volume of the head, and the fact that there is only one supplier.
but again as slade indicated, if all you want is lots of power cheaply, build a 302. you can make 400 normally aspirated horsepower from one with ease, compared to 200 horsepower from a small six. not to mention the amount of torque you can make from a V8.
building a six though is a fun challenge. it is also different.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
Ba Mustang
Re: 2bbl head
Post #15 by Ba Mustang » Tue Dec 22, 2009 9:39 pm
I've had that happen before too. Happened in May of this year at our annual car show. I was the last car to show up and people gathered around me when I popped the hood. It really caught some attention when they noticed it was an I6. I also won 2nd place in the occasionally driven class.
http://i193.photobucket.com/albums/z297 ... 91706a.jpg
That is what it looked like during the show except for the grille. I didn't have my corral installed then. It is going under a major change right now.
I plan on modifying the head of my 204ci I6. I'm going to go direct mount 2bbl HW5200, 1.56 exhaust valves and 1.84 intake valves, 302 valve springs, cam shaft, custom made turbo header(I want to try and make one), and turbo. Hope to finish that all up before next May so I can pretty much unveil it there. Also might be getting a set of 99 GT seats to go in it.
Current look: http://i193.photobucket.com/albums/z297 ... work/3.jpg
Gets 17x8 and 17x9.5 bullitt style rims next week, paint hopefully at the end of January, and eleanor side scoops.
2001 GT - DD
Users browsing this forum: chad and 26 guests
