how to fit a 250 in a mustang 66
euro mustang
Post #1 by euro mustang » Sun Apr 18, 2010 4:19 am
hello a have a stock 200 cid and a want to put a 250 cid (with ozzie head and triple su)in the car wath are the mods to fit it in my car the belhousing wil it fit on my stock 200 cid transmission or not a have now a 4 speed trans if a buy a bellhousing of a 250 wil it fit on my transmission and is it a big differens 200cid and 250cid thanks kristof
powerband
FSP Moderator
Re: how to fit a 250 in a mustang 66
Post #2 by powerband » Sun Apr 18, 2010 9:28 am
euro mustang wrote:hello a have a stock 200 cid and a want to put a 250 cid (with ozzie head and triple su)in the car wath are the mods to fit it in my car the belhousing wil it fit on my stock 200 cid transmission or not a have now a 4 speed trans if a buy a bellhousing of a 250 wil it fit on my transmission and is it a big differens 200cid and 250cid thanks kristof
With some pictures of your engine / tranny a definite answer could be determined if it will fit your setup "simply". with specific tranny setup in the Mustang now. 250 should fit but details of this swap are the fun part ...
Hmmm - - - SU's, That;s ambitous,,,
'61 Comet 250 T'bolt Six / SBF 157TFW/Bell/Clutch, Z-T5, 8"-3.80 Posi.
Powerband
euro mustang
Post #3 by euro mustang » Sun Apr 18, 2010 1:08 pm
how amitous i know it not fun to tune the carby s buth its a smooth look not ? the transmission belhousing a have from the 200cid is a baby against the 250 engine will a transmision of a late 70 or 80s fit or not v8 ? i know that the belhousing is the same as a v8of the 250 the engine was taken out of a mustang 71 with a auto trans c4 buth a want a 4 speed or 5 speed
rommaster2
Post #4 by rommaster2 » Sun Apr 18, 2010 3:28 pm
Since the 250 has the same bellhousing as a v8 all you need to do is get a neutral balanced flywheel (i wanna say 157 tooth but i could be wrong) and any v8 manual. I would suggest if your planning a naturally aspirated build going with a T5 as the overdrive gear gives you so much more fun since you can use a much lower rear gear (i run a 3.8 in mine and i turn 2500 going about 75mph).
If i remember correctly the problem you would usually run into is hood clearance, however with your carb plans i doubt that will be an issue. You would have to make sure your fender wells have enough clearance and then it should work.
euro mustang
Post #5 by euro mustang » Sun Apr 18, 2010 5:58 pm
:D nice buth can a just take my old 4speed transmission of my 200 cid with a v8 belhousing or not? thanks for al the info carb plans are not plans a have a lynx manfold and a ozzie head send to belgium :roll: not cheap greetz kristof
rocklord
Post #6 by rocklord » Sun Apr 18, 2010 7:55 pm
If your old 4-spd transmission is the Dagenham, it will not hold up to the 250's torque.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
AzCoupe
Administrator
Post #7 by AzCoupe » Mon Apr 19, 2010 12:59 pm
There's an nice article in the Tech Section about doing a 200ci to 250ci swap.
http://www.fordsix.com/250swap.php
Looking for Performance Parts, see Classic Inlines
Mike
Click here for larger image & info
euro mustang
Post #8 by euro mustang » Mon Apr 19, 2010 3:49 pm
thanks i will think about it lots of work buth is it worth or not ? :D
early ford fan
Post #9 by early ford fan » Mon Apr 19, 2010 7:38 pm
euro mustang wrote:thanks i will think about it lots of work buth is it worth or not ? :D
its worth it if you want fifty more horsepower.
Users browsing this forum: No registered users and 28 guests
