michael_cini
I put an older valve cover on my engine. the one with the oil fill towards the front of the engine and the PCV opening closer to the firewall. I noticed that the PCV valve opening is bigger. Is there some sort of grommet or is the PCV bigger, or??? Also, do I need to run a line to the air filter or can I just vent it? I have seen some cars with filters attached instead of lines to the air cleaner. Suggestions please.
Michael
Michael
