:wow:
  :mrgreen:
  :checks:  :thanks:
No disrespect to any of the above posters, as this is to inform and illuminte, and ulike some othe forums, we don't get kudos for blowing  out a creative delicate candle in the wind discussion.
Work in progess just inputing the dyno numbers Dyno 2, Dyno 3 and Dyno 4  based on:-
1. flywheel hp, not rear wheel hp figures given in Classic Inlines Dyno 2A and
2. the two other Australian Street Machine 1996 and 2002 articles published on the net here at FordSix 11 years ago ( back in 2002!)
viewtopic.php?f=5&t=5554&p=38262&hilit=+how+aussies+build%2A+#p38262
3. Required some work on making the rev range intervals 200 rpm, not 250 rpm, so I had to do a linear regression.
4. and lb-ft figures
For Car Craft,  see
http://www.carcraft.com/>http://www.classicinlines.com/Dyno2.asp
>>>>Dyno 1>>>>>>>>>>>>>>>>>>>>>>>Dyno 2>>>>>>>>>>>>>>>>Dyno 3>>>>>>>>>>>>>>>Dyno 4
Car Craft 2013>>>>>>>>>>>>>>Classic Inlines Dyno 2Aa>>2001 Oz Street Machine>>>>1996 Aussie StreetMachine
235 flywheel 203 cid engine>>>>266 flywheel 200>>>>>.199 flywheel hp 2-bbl>>>>236 flywheel hp 3 1.75" SU
RPM	TQ	HP>>>>>>>>>>>>>>>>>>TQ	HP>>>>>>>>>>>TQ	HP>>>>>>>>>>>>RPM	TQ	HP
2,500	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>2,500	225	171
2,750	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>2,750	225	171
2,800	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>2,800	225	171
3,000	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,000	225	171
3,200	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,200	225	171
3,250	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,250	225	171
3,400	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,400	225	171
3,500	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,500	225	171
3,600	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,600	225	171
3,750	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,750	225	171
3,800 225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>3,800	225	171
4,000	225	171>>>>>>>>>>>>>>>>>>225	171>>>>>>>>>>225	171>>>>>>>>>>>4,000	225	171
4,200	228	182>>>>>>>>>>>>>>>>>>228	182>>>>>>>>>>228	182>>>>>>>>>>>4,200	228	182
4,250	228	182>>>>>>>>>>>>>>>>>>228	182>>>>>>>>>>228	182>>>>>>>>>>>4,250	228	182
4,400	227	190>>>>>>>>>>>>>>>>>>227	190>>>>>>>>>>227	190>>>>>>>>>>>4,400	227	190
4,500	227	208>>>>>>>>>>>>>>>>>>227	208>>>>>>>>>>227	208>>>>>>>>>>>4,500	227	208
4,600	225	197>>>>>>>>>>>>>>>>>>225	197>>>>>>>>>>225	197>>>>>>>>>>>4,600	225	197
4,750	227	208>>>>>>>>>>>>>>>>>>227	208>>>>>>>>>>227	208>>>>>>>>>>>4,750	227	208
4,800	227	208>>>>>>>>>>>>>>>>>>227	208>>>>>>>>>>227	208>>>>>>>>>>>4,800	227	208
5,000	227	216>>>>>>>>>>>>>>>>>>227	216>>>>>>>>>>227	216>>>>>>>>>>>5,000	227	216
5,200	225	223>>>>>>>>>>>>>>>>>>225	223>>>>>>>>>>225	223>>>>>>>>>>>5,200	225	223
5,250	225	223>>>>>>>>>>>>>>>>>>225	223>>>>>>>>>>225	223>>>>>>>>>>>5,250	225	223
5,400	223	229>>>>>>>>>>>>>>>>>>223	229>>>>>>>>>>223	229>>>>>>>>>>>5,400	223	229
5,500	223	229>>>>>>>>>>>>>>>>>>223	229>>>>>>>>>>223	229>>>>>>>>>>>5,500	223	229
5,600	219	233>>>>>>>>>>>>>>>>>>219	233>>>>>>>>>>219	233>>>>>>>>>>>5,600	219	233
5,750	211	233>>>>>>>>>>>>>>>>>>211	233>>>>>>>>>>211	233>>>>>>>>>>>5,750	211	233
5,800	211	233>>>>>>>>>>>>>>>>>>211	233>>>>>>>>>>211	233>>>>>>>>>>>5,800	211	233
6,000	200	229>>>>>>>>>>>>>>>>>>229  xxx>>>>>>>>>>200	229>>>>>>>>>>>6,000	200	229
6,200	199	235>>>>>>>>>>>>>>>>>>229  xxx>>>>>>>>>>200	229>>>>>>>>>>>6,200	199	229
6,250	199	235>>>>>>>>>>>>>>>>>>229  xxx>>>>>>>>>>200	229>>>>>>>>>>>6,250	199	229
Summary: The Car Craft Dyno 1 cam pacakge is too much cam and raises the rev range too much. The Classic Inlines head is a high flow, low port runner volume head, and as such, its easy to wisk off efficency by have a cam too big for the port sizes and flow numbers. Its a little like Fords Cleveland engine, it responds better to the smaller 256 and 280 degree cams than the early 290, 300 and 310 degree solid cams. Although they made an extra 100 hp, the did so about 1000 rpm further up the scale. The Craft engine makes 30 hp less than Dyno 2a on Classic inlines, with 1100 rpm more, not as goos as making 266 hp at 5100 rpm. It made 211 hp at 5100 rpm at the wheels, which is better than 235 hp at 6200 rpm at the flywheel. That farily well sums it all up, its a loose torque, need more rpm combo which is inferior to Mike Raley's Mustang. I'd have his dyno tuned engine over car craft any day...the cam Car Craft used was was the Clay Smith hydraulic flat-tappet cam with 221/221 duration at 0.050 with a 108-degree lobe-separation angle and Yella Terra roller rockers verses Dyno 2a's 264-110 H, Product ID: CSC-264-HSP-10
264/264-110
The ideal combinations are listed for comparison. One is Dyno 3, a  12 port 2-bbl 4412 Holley XT5/XT6 Blue/Black Holden 202 cubic inch 3.3liter L6, and Dyno 4 Red l6 202 Holden GM Motor 9 port Triple SU carb and the Dyno 2a, the best 200 4V to date, the 480 Autolite equiped engine from
Comparing apples with apples is very hard, but  I did it above off the dyno sheets provided from four sources...
Dyno 1 is "as is", but with 250 increment interpolations
Dyno 2 is "as is" but with full 250 increment interploations from the video
Dyno 3 based on the left hand Test One 4412 500 CFM 2-bbl carb XT5/XT6 3.3 engine. The right hand side Test Two is the F9a Haltech port injected 3.3
3250 rpm......Test One 109 hp......Test Two 120 hp
3500 rpm......Test One 123 hp......Test Two 144 hp
3750 rpm......Test One 157 hp......Test Two 168 hp
4000 rpm......Test One 177 hp......Test Two 193 h
4250 rpm......Test One 177 hp......Test Two 200 hp
4500 rpm......Test One 188 hp......Test Two 209 hp
4750 rpm......Test One 195 hp......Test Two 213 hp
5000 rpm......Test One 203 hp......Test Two 216 hp
5250 rpm......Test One 201 hp......Test Two 221 hp
Maximum torque for Test One is 232 lb-ft at 4000 rpm, and 254 lb-ft at 4000 rpm for Test Two
Case 2: A later model 202, called a 12 port 3.3liter, runs a very good cylinder head, but a milder 280 degree cam.The headers are special Genie tube items. For the first dyno run, a 500 cfm #2300, 4412 Holley 2-bbl carb on an alloy intake manifold is fitted up to a cars engine bay. A control trans, tire and diff is used. The rear wheel horspower figures have been read off the chart, and turned into net flywheel figures by multiplying by 33% for the drive train and tires losses.
Then a 1985 GM Tuned Port Injection manifold is  placed on, with an EFI rail and a Haltech F9A fuel only electronic control module is calibrated on the rolling road. The figures between Test One and Test Two are listed below:-
4000 rpm......Test One 177 hp......Test Two 193 hp
In a vehicle weighing around 2950 pounds with a driver, there is a 14.2 second quarter with Test Twos EFI combination. The EFI system brings an extra 10% torque and power right through the rev range.
Calculations find that the 202 *RPM over delivered power is 4975 for Test One, and 4798 for Test Two. These figures indicate the engine maps as a "worked to an expert semi-race spec" machine.
Dyno Four is a culmination of of all detail from
Case 1: Holden Six, 202 cubic inch (1971 to 1980) . Head 9 port, engine is a miniture 230/250 with same bore spacing as FordS 144-250 I6's
Test one: Guy comes into Speed shop with an Eccon Rail with a 202 engine which won't past the 10.99 cut off for entry into the class. It has tube headers, triple SU 1.75" carbs, a worked head, 11.2:1 compression and HEI ignition. Dyno triggers 210 hp net at 4750 rpm, and torque peaks at the same 4750 rpm as 190 lb-ft. This shouldn't happen if the cam is sorted. Normally peak torque is at about a third this speed ( 3600 rpm). So the 308 degree high lift screemer cam is removed and replaced with a Waggot E3, a cam known for good results.
Test Two: the new cam is set at 22 thou lash, and the carbs get some ram tubes placed on them to smoothen the entry of air into the carbs. Dyno reads 222 hp at about 5700rpm, and now produces 205 lb-ft from over 5000rpm to 195 lb-ft at 3000 rpm.  Something is not right with the exhast tunning. The torque peek should still be at a lower rpm.
Test Three: Six dyno runs are done with lesser valve clerances until 10 thou lash gives 236 hp at 5250 rpm. Over 219 lb-ft at 5000 rpm. Still looks to be an issue with the exhast system.
Test Four: Some bright spark grabs a set of old cast iron twin branch headers, used on the touring car special XU1 GTR. These  on there own, with some tubing pipes running from them, loose 9 hphave shortened tubular pipes running off them for the dyno test.  From 3000 to 4000 rpm, there is now an extra 20 lb-ft extra, but maximum power is only 227 hp at 5250 rpm.
Test Five: The dyno operator tries an old motor cycle trick...painting the tubes in acrylic paint, runs the engine at hi rpm, and cuts the tube where the paint stops burning off. Suddenly, during the last run, a mighty 254 hp @ 5250 rpm appears. At 2500 rpm, there is another 42 lb-ft there! The torque peek is now much lower at about 3800 rpm.
Now, do the sums. 202 cubic inches, times 5250 rpm, divided by some factor, gives 252 hp. What is it? 4208. At the start, it was only 4570.
